Hello everybody, i just got my Nokia 6600
and i have a problem with the Bluetoth conection with the computer.
the problem is: everytime a try to conect the phone using the Bluetoth it finds the conection and after a second it's disconecting emself
by the way...with the Bluetoth software it's all good but with the Nokia pc suite i get the problem
if you need more informatin just ask me
thanks from advended
Flami
Flaminga wrote:Hello everybody, i just got my Nokia 6600
if you need more informatin just ask me thanks from advended
Flami
First, go to the settings of your bluetooth application and check if there is a com port assigned for client applications (e.g. PC Suite) that will use your bluetooth serial port. It should be assigned but if it is not, assign. If it already exists, keep the number of the com port (for example COM 8) in your mind and go to mrouter (the arrows in the taskbar near the clock) and check if the com port for bluetooth (COM 8) is selected. If not, select it and try again.
Regards,
I had just installed SP2, it is just release candidate so there are few bugs, on my Windows XP. It has integrated support for bluetooth. It works great but we have to wait for official version because I can not open some settings tabs(bugs). But anyway it is better than the original bluetooth application.
Microsoft should release it soon....
