Do I go Tools>Maneger to uninstall, installed .sis applications?
YES! 😊
Well if you ever download and use a filemanger whatever ya do dont delete the files in
C:\System\Uninstall
I thought they were just left over files so I deleted em, then realsied they were the unistall files to unistall the apps lol
so now if I want to unistall an app I have to go throuhg and delete it all by hand :|
can you reinstall the app then unistall it from the manager?
Osiris would you like me to send you that file and see if you can get it working again?
no its alright
it was only bounce, and some tiny apps
I removed the others bounce is all thats left
and I know exactly where that is located
Thanks anyway 😊
Ah..Sorry I misread you, I thought you deleted the uninstaller for the phone, not for a game. 😃
lol id format my phone if I deleted that or go get it serviced.
Yeah that's what I thought.
What is 'PsiNT Elib'
Is this a main program? It wasnt there when I bought the phone, and I have ony installed Seleq, eFileManager.
My App. Mangeger lists the following:
-SeleQ
-eFileMang
-PsiNT eLib(..
I think PsiNT eLib(.. is part of eFileMang, is it safe to delete?
THanks
Yes it is part of that program and deletes when you uninstall the main program, as it install's with the program, I think deleting it would be a bad idea, as I assume it is part of the main program. (If that makes sense)
