Hi People
i have just got a 6600 it used to be on orange but has been unlocked and now using an o2 uk sim, have done all the settings from the nokia website
but every 2 or 3 mins it pops up saying "select access point" the only setting i can find relating to this is GPRS and thats set on "when needed"
Thanks in advance
Curf
Curfish wrote:Hi People i have just got a 6600 it used to be on orange but has been unlocked and now using an o2 uk sim, have done all the settings from the nokia website
Thanks in advance
Curf
In Services /your browser, there should/may be a setting for default access point (set it)
In messaging there is one too (it's the one you do when you set up the pop3 or whatever box)
The Tools>Settings>Connection>Access Points lists all your access points. You can check them out there (these should contain the ones you got ota'd from nokia too).
thanks for the tip, but i did a reset of the phone by typing in *#7something#
and it restore the phone to orange settings which i have deleted and put in my o2 settings and all seems good
