i downloaded music videos and im tryin to play in on my p900 but it wont let me.... y????
How do i play video clips on my p900 from the computer??
Make sure the clips are converted to mp4's this can be done with Apple quicktime pro (win and mac versions)
say if i have a windows media player file i want to convert.... how do i do it??? i have quick time... plz guide me... thx
deggy wrote:Make sure the clips are converted to mp4's this can be done with Apple quicktime pro (win and mac versions)
say i have a windows media file.... how do i convert it??? i have quick time.... plz guide me... thx
My advise would be to search the forum. There are a lot of guides and topics about this.
There is a very extensive guide on HowardForums, however it uses pvauthor.
http://howardforums.com/showthread.php?threadid=231900
try this link http://www.packetvideo.com/info/p800/
'PvAuthor',
i used them for trail, its very good but if you want pay it, its cost �59!!! but very good.
or
try this link http://www.lonelycatgames.com/ (you see Smartmovie, click them)
'Smartmovie',
i used them for trail, its not bad. i wont do again them.
or
try this link http://www.makayama.com/moviemaker.html
'Moviemaker for P800',
i used them as well!, its allright but no sound!!!
good luck
any problems, you know where i am!
cheers
asdfasfasdf wrote:i downloaded music videos and im tryin to play in on my p900 but it wont let me.... y????
Try downloading dicas mpegable broadcaster to convert your mpeg files to mp4 format. in this way, you can adjust size of the media file to a smaller version and play music videos on your p900.
can you help me woh to best way download video from computer to P900 dan play it.....
