installing from MMC to MMC??
1 replies · 1,081 views · Started 31 May 2004
I know it is possible to install apps/themes/files to MMC from MMC, but how do I get the 6600 to find them after?? Can I choose a destination folder to install to??
Or am I stuck using the 6 odd MB for apps/themes and the MMC for files??
isischild wrote:I know it is possible to install apps/themes/files to MMC from MMC, but how do I get the 6600 to find them after?? Can I choose a destination folder to install to??
You can move the apps after you install them if you want them in nice folders. The 6600 finds them automatically if you have set it to use the memory card memory. You do this in a few places (ex: Messaging, options, memory in use, camera, video, etc).
Themes are found automatically w/ theme manager
(note that if you delete w/ theme manager you may also have remnants left in 'Manager' you can uninstall to get rid of the sisbomb.)
And of course...push the stick to the right in gallery
