Spy Call
3 replies · 2,858 views · Started 01 June 2004
I continue with the SPY CALL subject, does anyone know why if you install it it erases all your calendar entries?
I think I read that with apps using the Mophun game engine there is a bug that empties the calendar.
Any idea to avoid this? :?
I never learned how to avoid it (prolly can't be avoided at all..), but I used spycall for a while. I noticed, that if I keep the calendar and spycall running constantly, the calendar retains all the appointments. Also: I started using Outlook to sync my calendar daily, so that the odd calendar clearing wasn't a total disaster.
At the end (after a month or so) it got too annoying and I gave up, uninstalling SpyCall. You might want to try eRecorder from Psiloc: I think it does the job just as well.
-pete
