copying files from PC to p900
4 replies · 2,356 views · Started 01 June 2004
Hi
Can any1 help? I have recently purchased a p900 and want to upload some mp3 files from my PC to the actual phone. However after reading the manual and loading the software provided i an still unable to do so.
I have loaded the pc suite software but seem to only be able to sync or backup/restore data.
How do i see the memory stick?
Thanks in advance 😉
aman wrote:Hi
Thanks in advance 😉
You've got quite a few ways to transfer data over (cable, IR, bluetooth) but if you have (or want to buy) a card reader it's probably the quickest way.
Anyway, in terms of connectivity, do a search on this forum, I'm sure there are plenty of threads, also include in the search your operating system (PC)
And try Epocware's File Manager (tho you'll need to first establish a connection between the PC and the phone)
sorry for sounding thick...but can someone pls advise me on a gud memory card reader to buy - which will allow me 2 ciopy data from my PC??
If I was you, I'd just go down to your consumer electronics shop and see what they have. You can buy 4-in-1, 6 or even 7-in-1 readers, so if you have another format (eg digicam) you can use it for that.
I'd make sure you don't need to install drivers (ie true plug n play) since that helps a lot when using it on different PCs
I bought one about (6 in 1) about a year ago, for about �20, I'm sure they're a lot cheaper now, everywhere
