WHat are the keys used , to play the roms in the 900.
I am using goboy800 application.
goboy - p900 problem ?
kakubaba wrote:WHat are the keys used , to play the roms in the 900.
The on/off button usually starts games (don't worry, it won't turn off your phone) and then, it depends on the game. Most have on screen controls using the stylus, or if you use the P900 in FC mode you can use the keypad (2 - up, 8 - down, 4 - left etc).
Sometimes it's a bit of trial and error, but it usually easy to work out once the game's going.
If you aren't using the latest version of GoBoy you may need to select the "lock screen" menu item before pressing any keys - the current version dispensed with this annoyance.
