I recently bought a 64mb mmc card . Can anyone tell me the best way to transfer te files from the existing mmc to the new one .
MMC
Best way may be MMC USB reader?...
If you dont have it, backup your old MMC with Pc Suite and restore it to new one.
There's also somekind programm to move your data from mmc to another without pc...
Regards
Yes, I have that program. It�s called Card Mover. It works fine. $10
Try it!
Remember it when you�ll have the 128MB MMC, he, he, he...
Regards!
Hi, i think a usb-reader as it can be used for other purposes that use MMC ![]()
I use a USB Reader / Writer from Dane-Elec
Works great ![]()
I have s Zio MMC/SD reader. The great thing about these is that they are so small. Even the cable is a seperate item, so you have the option of plugging the reader (without cable) straight into the USB port.
Zuber
I got mine from www.scan.co.uk, it unbranded made in Tiawan, but with digital cameras that take Smart Media and an IBM Microdrive, this reader is quite good as it takes all 5 different types of Media (MD, CF, MMC, SD, SM) and all at the same time so you can move from one device to another
- but Win2K is a bit funny about it and sometimes you have to go into "Manage Computer" to get it to see it the first time you use it after booting up.
