Hi
Can someone pls advise me on a decent memory card reader i can get for my P900 (to copy data from PC).
I didnt know you had to purchase a card reader after spending soooooooooo much on the fone! 😉
Hi
Who says that u need a card reader to copy data to the phone? U can use the phone's cradle to copy anything you want in its memory... unless ofcourse it is too slow for u, so in that case a card reader would definately be a much better solution... 😊
}literal{ wrote:Who says that u need a card reader to copy data to the phone? U can use the phone's cradle to copy anything you want in its memory... unless ofcourse it is too slow for u, so in that case a card reader would definately be a much better solution... 😊
Can you please explain 2 me step by step how i can use the phones data station to copy data across? I have connected the fone via a cable connection. However all i am able to sdo with the pc suite software is synchonise data, backup/restores and install software. I am unable to see the actual memory stick.
Please help!
you can download PC File Manager and it'll do the job!
hAnDyGUY wrote:you can download PC File Manager and it'll do the job!
Thanks for your help 😉
Any ideas why it is not possible to see the memory card (to drag and drop data) using just the standard supplied software (pc suite).
All i can do is restore/backup, sync and install software.
Im just curious 2 know!
Thanks Again
will the trial version be sufficient to copy a few mp3 tunes across?
i dont know about u, but when I installed the pc suite software from my P900 cd, it created an icon on my desktop called My P900... from there i can access both the phone memory and the memory stick when i connect the phone either through the cradle or bluetooth... and i can copy anything i want on both memory locations... so maybe u should try installing the pc suite with the full option selected?
