Is it possible to apply a 'TZoomFactor' to text in the 'RichTextEditor'?
0 replies · 1,456 views · Started 02 June 2004
Hello,
I downloaded the Symbian OS 'Type' Example (RichTextEditor v1.0) and I am wondering whether it is possible to apply a 'TZoomFactor' (e. g. EZoomOneToOne*2) to the text in the RichTextEditor.
The RichTextEditor should be used in a series 60 application and the highest font size available on a nokia 7650 seems to be 'LatinBold19'.
Is it possible to display a higher font size than 19 by using a zoom factor?
As I am a total beginner (sorry!), where do I have to place the code for that in the example code of the 'Type' Example?
Thank you for your help.
Kind regards, Lars
