Problem with MMC?
6 replies · 1,668 views · Started 02 June 2004
Hello everyone. I had some problem with my memory card and so i formatted it using the option given in the phone. After doing that, I installed some applications and loaded my images. When I click on the memory detail, I am able to view the size of the images and video clips but not the applications. Please help me as I was able to view the memory details before formatting. Thank you.
Regards,
Pradip Udayakanth C.G.
u can the memor application in the phone application manger
and u can see other details in the option u r using in the mmc option "view memory details"
main option are....
mmc messages:......all messages using the memor of mmc
images... all images not inculing the _P... folders
sound and videos
and application
it use that memory which the extra files all the app have used.
and the rest is in application mager
if u have manu app it will take 2 to 10 sec to load all files.
pradipudhaya wrote:Dude, I reallly don understand head or tail of what you are talking about
It seems to count only the size of installed Java apps.
As long as you don't have installed any, the size for Applications remains ' 0 B'
That's at least what my handset does.
Regards,
My 5 year olds brother had block my MMC by password and he can't remember it.What can I do now?I can't format it. Please tell me how to solve this problem. Thanks for your reading.
monoc wrote:My 5 year olds brother had block my MMC by password and he can't remember it.What can I do now?I can't format it. Please tell me how to solve this problem. Thanks for your reading.
I don't have any codes, but you can do a backup w/ a card reader and grab everything. You can reset your phone as well. Just be careful w/ things. It might be a good idea to do a mmc copy to a pc, then using a new or formatting that mmc do a backup of the phone memory and copy that out seperately.
There's probably a much easier way.
