Nokia Calendar
10 replies · 2,738 views · Started 02 June 2004
hi everybody...
in the system or another place which file stores all Calendar entries?
(for backup the calendar) cuz i dont use outlook or another program for synchronization...)
and one more question is there a GOOD calendar program another from nokia calendar?
The Calendar data is stored in the file "c:\system\Data\Calendar".
What does "a GOOD calendar" mean, exactly? "GOOD" is a a very subjective word. What's good in my opinion may not be good in your opinion.
If you can't define it, how about if you say what is not so good or missing in the built-in Calendar app (in your opinion)?
bro c:\system\Data\Calendar is a exe file how this can be the store file ?? i dont interrogate u just a question😊
in my opinion nokia calendar has some missing things... ex : i cant see the whole day in one screen (ex: u wrote somethink at the 08:00 and another one at 23:00 u cant see these in a page) the hours that written at the right column are very unnecessary! and birht days are the second important thing! etc,etc...
so i need to install another good calendar ok? 😊 😊
I would like to find a better Calender too. Not only the problem of showing the whole day (which by the way I think has been fixed for the Nokia 6600), but also that there is no field for "Notes" like there is for Contacts. Post back if you find anything and I'll do the same.
Does PC Suite's backup utility not back up the Calendar data?
hatehate wrote:bro c:\system\Data\Calendar is a exe file how this can be the store file ?? i dont interrogate u just a question😊
It *IS* the Calendar data file, not any kind of exe file. Why do you think it would be? The actual Calendar application is z:\System\Apps\Calendar\Calendar.app
Active Desk offers a couple of improvements over the normal calendar display, and also the to-do lists etc. See if it's for you... <http://www.cibenix.com/AD7650_index.html>
NickC ; pc suite can backup the calendar data off course...
and the other ques; just ask cuz it is an exe files ok and thanx very!
aquawell, ur program is very very😊 nice as seen.i didn't install it yet but compatible devices that written are: Motorola A920, Motorola A925, Sony Ericsson P800, Sony Ericsson P900.
so deos this program work on series 60?
aquawell, do it plz for 60 series cuz there isn't a good calendar for 60 series! (in fact there is no calendar for 60 series lolz!)
