help with psiloc IR remote
2 replies · 3,906 views · Started 02 June 2004
I used a demo version ages ago but decided it wasnt good enough. Ive tried to test that lastest version form the website and when i install it, it just says demo has expired? anyone know where the regitry file is located for IR remote so i can get rid.
cheers
Mike
hi,
try uninstall the ir-remote
try to install: registery cleaner into your phone and run to clean if you cant clean all files of ir manually.
then reinstall it again and it wil work
