yet another Memory card problem!!!!
5 replies · 5,620 views · Started 02 June 2004
ok i was messing around whit the n-gage and files to put on a 64mb mmc so i was like checking what stuff could i do
so i was looking around on the Windows explorers while the n-gage is connected and i right click on the F drive (which is the mmc) so it say the regular stuff and also have the format option so.... i click it and i format the memory card throug the windows explorer ......after i unplug the n-gage and try to see it on the fexplorer.....i couldnt
i went to tools>>> memory and it told me the memory was corupted and that it needed to format so it did and went ok ask me for the name and then i try to plug it again to the computer ....but i couldnt ....then i format again ...but my computer didnt recognize it so i try a couple of more times, then i got despered and check all the wires on the pc .........:|.......all of them ..i didnt know the back of the computer could get so dusty....:S .......then i remember i have another mmc so i put it on and it recognized ...so i put the other one back on and again nothing the fexplorer recognized i even can cut paste stuff from the internal memory to the mmc but my computer just dosnt recognize the demn thing!!!!
did i just screw up the mmc card??
what can i do????
ahrg
blindpilot wrote:yo thanks man my boss have one off those ill try it tonight 😃 😃 :icon14:
hey barn i tried it
😞 didnt work the usb card reader im using its a avantec 7 in 1 external reader/ writer i plug it in install it it work but theres is no option to format the car under FAT 16
the software only have a multimedia card reader utility which only gimme the option of create a star up disk i did and i put it on the n-gage now besides that it dont read it on the pc after i tried to format it on the n-gage it says its corrupt :|
so now what????
