Hey everyone!
Did you know what code is for battery in nokia 3650? I need this code becouse I must recharge my battery every day.
2 days left I was formating my phone because WIDSKINZ :icon13: had crashed my system 😮 and now I have averything new :?
I asking You for this code becouse it it in other phones NOKIA, and maybe I was have it before formating....
Ps. Sorry for my not-perfect english 😉
Not code for battery name, but code to saving life battery...
Just like for numer IMEI is: *#06#
And what code is for saving time of working battery??
Or it is that code? Becouse in other phones is; in other Nokia phones is 😊
There is no such code for "saving battery life". Not for other Nokia phones either.
On some phones there are codes that can be used to change, e.g., the default voice codec.
Some have the illusion that changing the default from the default EFR (Enhanced Full Rate) to HFR (Half Rate) would somehow use less power, but changing the setting won't really have an effect, because in practice it is the network that's really deciding what codec is used (and the network always uses the best quality codec it can).
Etc.
Main point is: The phone and its software already has been designed to use as little power as it can get away with, and there is nothing you can do (except to use it less; make less calls, run less applications, etc.) to save battery.
If one battery isn't enough, get a second one that you carry with you & which can switch to when you run out of juice with the first one.
OK Thanks... Maybe it cold be app: sceensaver :?
