hello every one
i am finding the soluation from a long time
i am using wap.
when i download/save the setting
and go in services and connect that connection.
then it go on connecting "data call is being made" after one min data call
the serices give me a error Internet: unavle to perform service operation"
i am really fed up
i have gone to the service provider reagrding this
he put all the setting manullly and then same error repeats.
then a person near by told a site name."sambiaian.com" but is not exiting
he told me that download a patch(sorry if its illeagel bcoz i don't know)
and then the wap will work
please some one help me regading this problem.............
not anybody can answer me......
i am really fed up from this prob
please does anyone have the solution...
hi vicky, i've recently stopped using my gprs.deactivated it just yesterday. r u using hutch or what? i can let u know my settings. they are as follows
i went to tools>settings>connection>access points and created this one
connection name: HUTCH_GPRS
DATA BEARER: GPRS
ACCESS POINT: portalnmms
user name: none
prompt password:no
password: none
authentication:normal
homepage: http://in.wap.yahoo.com/
connection security😮ff
session mode: permanent
then clicked options>advanced settings
phone ip address: automatic
proxy server address: 10.10.1.100
proxy port number: 9401
thats it. the settings that they sent to me were not enuff as advanced settings were not made thru it n i made them manually. c if u get some help from all this epic. expecting thanks after hoping it worked for u. by the way i used it in gujarat.
Take Care
Pallav
Goodmorning mates,
You probably have some N-gage games installed on youre mmc,
try internet without youre mmc. When it works just fine then, delete
all the ngage date.
Worked for me.
Marnix (Holland)
