N gage Problems
13 replies · 4,706 views · Started 03 June 2004
Hey there, this is the first time i have used this forum and i would just like to ask a few questions. I have had my N gage since Oct 2003 and I am completely dissatisfied with it thus far. I am on my 3rd phone as the last two have ended up with what people call the white screen of detah where it would not start up. Anyway, my main propblem with the phone is that no matter what PC i use PC suite never detects the phone, therefore I cannot add ANY applications which is one of the main reasons I bought the phone. I can however access the E: when I use the USB lead to connect to my PC, from My Computer I can add and delete various files. I cannot install applications or use any of the functions available in PC suite. I would appreciate anyone instructing me how to install Apps manually through MY Computer or suggestions as to how I can get PC Suite to work. Thankyou very much. Ben. :frown:
Do you have Bluetooth on the PC? PC Suite does not work with the USB cable. Only Bluetooth. It is mentioned in the N-Gage User's Guide.
I didnt realise that, no my PC does not have bluetooth, thankyou for clearing that up. So how can i get applications onto my N gage? I have downloaded the Mega Drive Emulator that has been dicsussed but i how can I manually install it with my computer?
For example, you can put it in the root of the MMC through the USB cable and use the "Manager" app to install it.
sorry to post in this old thread.. but I have the same problem.....
How can I put applications that I've downloaded into my N-Gage through the USB cable without using PC suite...
When i connect it it comes up with a few folders, I've tried putting the .sis file into all the folders there but it doesnt appear in the application manager thing wherever I put it...
Can anyone help?
You can't install apps with your pc. After transfer apps to your mmc card root folder, you should disconnect your n gage with pc , then go into tools-->manager,
find and select your app in mmc card, use options-->install, then install is begining.
Yeah, I know that, but which folder is the mmc card root folder? I've tried all the folders that come up and cant find it.......
root folder is the top level folder, that's mean in your pc explore if your mmc card shows as " local disk I: " , just put the app in it, not any folders of the disk.
Your app in your mmc card should like this , I:\appname.sis .I think you can understand me. good luck. :tongue:
bobmwang wrote:root folder is the top level folder, that's mean in your pc explore if your mmc card shows as " local disk I: " , just put the app in it, not any folders of the disk.
but in mine there is no disk i instead there is d what should i do?
If not so ,you are a very junior one. Or I did not explain well, really sorry.
local disk I: means the ngage mmc card recognised by pc, it's the new one added into your pc explore just when you connect the ngage to your pc. It can be lcoal disk
D: or E: or F: just depends on how many disks on your pc already.
by the way ,My english may be not well. you can correct my phase. thanks.
:redface:
bobmwang wrote:If not so ,you are a very junior one. Or I did not explain well, really sorry.
:redface:
i can install sis app via usb but how can i install .rar ngage games to mmc via usb?
The games in .rar files are usually illegal, cracked copies of N-Gage game card games. No discussions about such are welcome on this site.
The easiest way to install a game in a .rar file to an MMC is to get your wallet, go to the store and buy it already on an MMC.
Wirelessly posted (Nokia N-Gage: NokiaN-GageQD/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Yeah, piss off to another site you cheap prick!
