Check this out, http://www.p900er.com/product.asp?id=1488&model=p900
Cool Stuff! Home Theater for P900
Very cool! A bit expensive maybe... But cool! 😃
Delta737 wrote:Very cool! A bit expensive maybe... But cool! 😃
It's actually not too costly considering it's a sync cradle, charger and speakerphone on top of the stereo speakers.
I agree with you. Relatively speaking it's not expensive, but as just an accesoire to a phone that I probably won't keep longer than a year it is quite expensive IMO(unless it's compatible with the P900's successor too offcourse 😃)
I wonder about one thing though. It says "230V - UK Plug". What do they mean by that?? I can just connect my own "european" connector now can't I? :?
Delta737 wrote:I wonder about one thing though. It says "230V - UK Plug". What do they mean by that?? I can just connect my own "european" connector now can't I? :?
Just use an adaptor and convert the 3pin UK connector into the European connector. It should work fine as long as the voltage is the same.
So it has a connector built in? It's not like on the normal docking station than you can just insert the charger (if you get what I mean)??
