setting up Password based access to applications
6 replies · 3,358 views · Started 04 June 2004
[B]hi!
i own nokia 3650. i have installed Appmanger(appman60.sis) and filemanager (FExplorer_english_111.SIS) applications on my phone. these two applications are very senstive as they allow you to format and delete even OS files of the phone.
can we have these application password based access to make phone more secure.
Is there any application which which allows to make applications access password based for nokia 3650. like we have password based access to our security settings.
Please give me detail if any one have.
Abhishek[/B]
I haven't heard of any such applications.
If you let other people you don't trust use your phone, don't install any dangerous applications on it.
If you do (or even if you are the only user), use them carefully.
hatehate wrote:man the program u needed is : SmartCrypto...
thx
but SmartCrypto works on file level i want it on folder level. is there any other software which work on folder.
abhishek
Hi, u can hide any applacation and any java game.For prevention of unauthorised use of up f explorer,u just encrypt the file with extension .app in the folder fexplorer.For java encrypt jad file thats it.It will work
hy i also have a 16 mb memory card but i can`t use it becaus eis blocked and i don`t know the security code .what should i do?please help me
I have a solution to this problem, but you should mail me at the address to find the way and you will be registered.
[email]sorryNotHere[/email]
