i need to make my sony p800 communicate with an arm kit with symbian OS. the p800 needs to send some message to the kit, then the kit will respond with the reply to the mobile. the communication needs to occur OVER THE AIR.
how do i begin writing a program to do the same..
please can anyone help me on this
deepika
www.sonyericsson.com - go to developer section
1.download sdk
2.check out from sdk the type of connection you want to have (Bluetooth/GPRS/...?)
3.check out example source/modify it for your needs
4.in case of troubles visit sonyericsson site - go to developers forums and search for answer/ask you question
hope it helps
thanks for the directions.
