3650 fixed from other day....
5 replies · 1,775 views · Started 04 June 2004
I had the same prob the other day took it to nokia centre they upgraded software to 4.13 20/08/2003 from 2.5 I think. Anyway it works now but all my data is lost, and some of the programs on my card such as stack up wont play anymore and I cant delete them? why is this?
also is 4.13 the latest software version then? whats new compared to my old v 2.50?
thanks
Liam
Flashing lost the installation log (uninstallation info). Reinstall the apps. Then you can uninstall them.
i really wanna keep them tho, if I install them again will they be full versions like they were before?
anyone know where to get bowling2 fisherman and stackup?
well frist you need to format your mmc card cause you dont want to have any old software running on the phone you need to re-install whatever you want format the mmc card and as for the new firmware 4.13 no difference accept the phone does not hang as much as well as it runs new softwares better
also in the currency rates in 4.13 there is no option to alter the currency rate of USD USA dollars is there? is this another bug?
