64mg MMC for 3650 not working
4 replies · 1,729 views · Started 04 June 2004
Hi. I have a Nokia 3650 and have been using the 16mg MMC that came with it for about 7 months. I decided that I wanted more memory and bought myself a 64mg MMC from Jessops photoshop (UK). When I placed this in my phone, my phone says that there is no card inserted. Any suggestions please? Thankyou.
You could try to format it, but if the Memory app doesn't see it, it could work if you format it in a PC with a memory card reader (should be formatted as 16-bit FAT or VFAT).
If that doesn't help, I'm afraid you have to return it and try another brand.
Hey, thanks for your reply. Any suggestions where I can get a memory card that will work in my phone? :? :icon14:
Tortoiseboy wrote:Hey, thanks for your reply. Any suggestions where I can get a memory card that will work in my phone? :? :icon14:
If this helps you:
I bought an 64MB MMC-Card from Scan-Disk! Plugged it in, worked from the start!
And I didn�t had any problems with it so far...
Hey! Thanks for your advice. I took my card back and had it checked. It turned out that it was a faulty card. They replaced it and it works fine now.
