[FONT=Arial]I[FONT=Courier New] need to get games on my phone 😃 I do not want to pay as I own the phone (not on contract or plan) Can some one direct me to a good site or if you develop can you help me out with some Beta files to try? 😃 [/FONT] [/FONT]
A925 Games
For quality product,you will most likely have to pay.Try the shop: http://www.allaboutsymbian.com/shop/
BTW:One of the best freeware apps IMO is PicoDrive.
All the UIQ(p800/p900) apps and games should work on the A925.
Ghostdog, that is totally incorrect. As a matter of fact, a large percentage of P800/P900 software DOESN'T work, even with the P80xSoftwarePlatform installed.. A couple of quality games that do work on the A92x are:
Tags : Tanks
Legacy
Lemmings
EDoom
and as far as emulated games go, try:
Picodrive (Megadrive/Genesis)
GoBoy (Gameboy/Gameboy Color)
EMame (Arcade)
The emulators give a huge range of games, so give em a try 😊
Regards,
A92x
P80xSoftwarePlatform doesn't need to be installed at all.The only problem is in the packaging.Developers need to sign the sis file as a generic UIQ app and it will work.Most of the should work by now.
I can't get goboy or emame to install, it just keeps saying that they are not designed for my handset
how do I install them?
I don't have this p800 thingy installed, do I need it?
I know I am useless but I need help
Lith
E-ScummVM (Symbian compilation of ScummVM)
To play some old games like Monkey Island and Simon the Sorcerer on your phone =)
It's really SWEET !! 😉
