A great friend game me a 9210i with a Dutch interface. I need to get an English version and so far I've found no one at Nokia in Hungary (where I live) to help. Any ideas?
Changing to English Interface for 9210i
Try to get an software upgrade (or redo the software upgrade). Because the software language in the ROM needs to be changed. You cannot change it yourself.
Happened to me as well. I have an English 9210 although I live in Finland. During my first upgrade from 3.54 to 3.62 the Nokia shop installed the Finnish version instead of English. There I was English buttons and the rest in Finnish... 😃 They had to do the upgrade again and everything was fine.
As long as you have warranty, it should not be a problem. Otherwise you might have to pay for it. But in principle it is possible to change the UI language (just not by yourself!).
HTH,
Tilman
Switch it with my 9210 english version 😉
Then we are both happy 😉
