hello i wanted to know plz 2 things the first
*what is the easy way that i can send picture from my 6600 to the computer
because i taking picture and i dont know how to bring them out to the computer
*can i see in my 6600 television live brodcast like channels if yes how
thanks for your time i houp in the next few days ill help in this forum too
*what is the easy way that i can send picture from my 6600 to the computer because i taking picture and i dont know how to bring them out to the computer
Select picture, hit "Options" and choose the "Send" menu. If you send over Bluetooth, your PC must have Bluetooth. If you send over infrared, your PC must have it, too. You can also send as email to an account you access from the PC. If you use PC Suite (using Bluetooth or infrared), you can also use it to copy pictures from the phone to the PC.
No. The 6600 does not have a TV tuner. If you find a television channel that's been offered as a RealVideo stream over the network, you can view that. Note that most operators charge GPRS data by the megabyte.
