Problem with menu after app.install
1 replies · 1,699 views · Started 05 June 2004
I just downloaded a trial of an application named MSMSMoney (or something like that).
At the end of the installation, I got a message which said something like "you can't install a file that excist"(?)
Whatever - my problem is : After the install, some of my menuItems has changed name.
The camera is now called: "Cmra", My control Panel is named "qctrlpnl" and so on.
Does anyone know how to fix this? I've tried resetting the phone and install earlier backups without any luck.
Please help 😊
Regards
Per M
