6600 PC Connection
6 replies · 1,739 views · Started 05 June 2004
Right you guys - here are some questions which will not tax you at all:
I've ben deliberating over 6600vs6230 for ages and have decided that the 6600 is a far more exciting prospect. I recon its a much more powerfull tool provided it is used well.
Firstly does the phone come with a way of connecting it to the PC so that the software can get onto it?
If you wanted to tell someone what the most useful features/additional programs for the 6600 what would they be and where can I get them?
Sorry to ask such basic questions.
Any other tips/advice greatfully recieved.
You need to buy a Bluetooth or iR dongle to connect to pc (Cheap now they are so common). Or use a card reader (which is a pain,as mmc is under battery).
There is not one single app that could be recomended as there are so many!
(Think of that as a positive).
For a list of many apps (but certainly not all) go to the Shop above,which is obviously where you could get them for you last question).
Many thanks.
Gonna get the phone tomorrow o2 online!
Hope that all these dreaded bugs don't crush my curiosity.
What's firmware and how do I update it?
DrJ wrote:Many thanks.
Most of the buggy phones seem to be on Orange (Funny that) as they have there own firmware version,) my firmware is still the original v3.42.1,as i have had no problems with it (In nearly a year,touch wood) and the new one has a lot of restrictions (and still problems) so I have no need to upgrade.
*#0000# to check firmware when you get (which should be the new one v4.09.1
Check for dead pixels on display before leaving shop/or if delivered,as soon as out the box. (search this forum for more info on that)
elton wrote: Or use a card reader (which is a pain,as mmc is under battery).
Elton, I'm not clear on that one, although I haven't tried using my mmc readers on my pc, they seem to work fine on my mac (just rename the card so it has a set name and try a plug/unplug). I thought most readers would support bus power so the mmc shouldn't have a problem. What's the exact issue w/ using a card reader and the mmc 'being under battery' that you're talking about ?
JasonT wrote:Elton, I'm not clear on that one, although I haven't tried using my mmc readers on my pc, they seem to work fine on my mac (just rename the card so it has a set name and try a plug/unplug). I thought most readers would support bus power so the mmc shouldn't have a problem. What's the exact issue w/ using a card reader and the mmc 'being under battery' that you're talking about ?
I mean its a pain,coz you have to turn the phone off,remove battery cover,remove battery and only then can you remove mmc. 😊
elton wrote:I mean its a pain,coz you have to turn the phone off,remove battery cover,remove battery and only then can you remove mmc. 😊
Doh, I share your pain.
