I HAVE SAW PV PLAYER IN P900 I WAS GREAT IMPRESS REGARDING FULL SCREE VIDEO
I PURCHASE FROM PACKET VIDEO SITE.
AND NOW WHEN I USE REAL PLAYER ORIGNAL IN THE PHONE
IT SAYS " Uable to Play Media Clip"
and when i offenly use the video clips , evey time it use pv PLayer and not the real Player
if i want to use the REAL PLAYER wht i have to do that i can use both of them as i want to use both
AND ONE QUES MORE
WHT IS THE PROCESS WHEN I AM PLAYING THE CLIP IN PV PLAYER
HOW CAN I REVERCE AND FWD THE CLIP
Vicky wrote:I HAVE SAW PV PLAYER IN P900 I WAS GREAT IMPRESS REGARDING FULL SCREE VIDEO
I PURCHASE FROM PACKET VIDEO SITE.AND NOW WHEN I USE REAL PLAYER ORIGNAL IN THE PHONE
AND ONE QUES MORE
Sorry, I don't know how to change the recogs for media handlers (this should be simple to do for a user), but did real play the file before you installed pv or whatever? Real can't play certain things that the normal desktop ealplayer can (AAC etc). Then next build of helix should. You could always look at the installs file to see what pv installed and see if there is a recog you could remove. It could break your install though.
i didn't get u wht r u saying
well i am facing the prob i want to see the full screen video and to use real player too
i have one more prob when i recive video file in my message inbox it open in pv Player so thats why there is no option of save in any other foler thats why i want to use real player.
Vicky wrote:i didn't get u wht r u sayingwell i am facing the prob i want to see the full screen video and to use real player too
The way an application works when it is activated from the inbox and when you launch it yourself are different. Just quit pv when you get a video in your inbox then launch real. If it previously scanned your inbox it should still be able to. Otherwise you can use fexplorer to move the clip then open it as a saved clip. I'm still waiting on helix 1.1
i have fine the new version of Pv Player
it a good program and doooo everything i want...
full screen ,save , small scree stc stc
