No More Outgoing Calls For My 6600
1 replies · 1,942 views · Started 06 June 2004
Within the past two days i have been unable to make outgoing calls with my 6600, also all of a sudden a small number '2' has appeared underneath the battery indicator. I have no idea what this means or what has caused it, i have tried resetting the phone back to factory settings but it still remains. I have no idea how to fix this, any help would be great. zee
zeewee wrote:Within the past two days i have been unable to make outgoing calls with my 6600, also all of a sudden a small number '2' has appeared underneath the battery indicator. I have no idea what this means or what has caused it, i have tried resetting the phone back to factory settings but it still remains. I have no idea how to fix this, any help would be great. zee
your phone is switched to line 2. to switch it back hold the # key in stby mode, you'll see "change outgoing phone line?" then hit yes. that should fix your problem
