Hey! I've just got a memory card reader and hoped that I could transfer app installation files (sis) to my phone via the memory card, but I cannot find a way to do it. My system is 98SE if that makes a difference. Thankyou 😎
Transfering sis apps to 3650
I found the easiset way to transfer sis files is to set up the phone to receive email form you POP3 email account (like the one your ISP gives you) and then send yourself the sis file as an attachment. THen just open it upin the phone and download the attachemnt and then all you ahve to do is install the sis file. Given you have a 3650, which you do and unlimited Data (like Tmobile plans)
Have u tried using file managers like Seleq or F-explore? I think theres a directory called c:install (not sure) or something from there u can copy the file and run it to install the sis.
Did that help?
switch ur sms memory to mmc card that way u want have any mem problems
sorry wrong post
