Every so often my 3650 says "memory full delete some data" ok well every so often is non stop. I can not check my emails, open most applications, or install anything. I of course have tried deleting junk, formatting my MMC, and running in flight mode nothing seems to help. When I dial #7370# it says request not completed. My only other option to format then seems to be to use the already installed system tools program but when I go to register it has to download the latest version which crashes. Its branded cingular and in utah there arent any cingular stores. I dont have any idea where a nokia store would be either. Any at all sugestions besides throw it at the wall would be very helpful
neocarbunkle wrote:Every so often my 3650 says "memory full delete some data" ok well every so often is non stop. I can not check my emails, open most applications, or install anything. I of course have tried deleting junk, formatting my MMC, and running in flight mode nothing seems to help. When I dial #7370# it says request not completed. My only other option to format then seems to be to use the already installed system tools program but when I go to register it has to download the latest version which crashes. Its branded cingular and in utah there arent any cingular stores. I dont have any idea where a nokia store would be either. Any at all sugestions besides throw it at the wall would be very helpful
I think u mean *#7370#
Try using a file manager like seleq or f-explore and ull see a drive there I think its D, where I suppose a program is loaded on execution maybe thats full. I also think that formatting the mmc if the phone memory is full, makes it useless since what really is full is its so to say, buffer drive, the D drive.
Correct me guys if im wrong.
Instead of throwing it on a wall throw it somewhere here I could sell it for u or something... 😃
it was *#7370# boy do I feel stupid but thank you soooo much
