SMS T9 input problem
1 replies · 1,479 views · Started 08 June 2004
If I use T9 imput using romanian language the length of the message drops. So if I write a mesage using T9 that has 160 car. it sens it using 2 or 3 mesages. I think this is because it uses special letters that are found only in romanian and doesn't replace them with standard letters. I have the latest firmware verion 4.09.1. What can I do?
oGu wrote:If I use T9 imput using romanian language the length of the message drops. So if I write a mesage using T9 that has 160 car. it sens it using 2 or 3 mesages. I think this is because it uses special letters that are found only in romanian and doesn't replace them with standard letters. I have the latest firmware verion 4.09.1. What can I do?
You're probably right about the formatting. Does the same thing happen if you don't use t9 completely (turning off in the settings so it never softkeys?)
