nokia 6600 headphones ?
2 replies · 2,497 views · Started 09 June 2004
ok just got my new 6600, though what are the best headphones , or handsfree set to use ? want to be able to watch movies and music, just cant find any on the net apart from the old style ones, thanks
tomk_bucks wrote:ok just got my new 6600, though what are the best headphones , or handsfree set to use ? want to be able to watch movies and music, just cant find any on the net apart from the old style ones, thanks
Since you only have one audio profile for the 6600 it really shouldn't matter as long as you have bluetooth 1.1 and above support. The best headphones are the ones that feel the best on your head. Jabra seems to work for me. I think they did a revision to their firmware because you can tell they disconnect the channel from the phone when you're not using it and the battery life seems to run forever, but other than that I tried on some plantronics and they felt great. The bodyglove foldable is cool looking, I don't know the specs. Now if you find something that lets you switch between devices from the headset let me know because that's a winning headset to me.
i mean headphones to listen to music, movies etc, i think the old headset from my 3330 will work with it for handsfree,
