Contacts and Calander
2 replies · 1,795 views · Started 09 June 2004
Allon Reiter wrote:I am looking for a software for Contacts and Calander, can you suggest.
Allon,
What do you want the software to do and what platform are you using? You can search through online shops for all kinds of software that manipulates the contacts and calendar applications built into your phone. For syncing on a pc you use the suite from nokia (free) and choose which apps you want it to sync the db into. On a mac you use ical, addressbook, and isync for a little better sync, but a headache getting the connection just right.
JasonT wrote:Allon,
I am using the nokia sync software for the outlook and phone, I am looking for a more advanced contacts software (with more find options and views by company name) and calendar which can show you also the notes in the outlook calendar.
