ANYbody feel in the mood to help me connect my 7650 !!!!
1 replies · 2,425 views · Started 23 September 2002
Anybody feel bored enough to try and help me connect my 7650 to my PC, I am desperate now I need to sort out my contacts can I do this without the Nokia Software ie Just sending a file Via bluetooth to my pc for editing. 😞
I have mine connected via IrDa. I don't have a bluetooth card :-? You don't need PC Suite to transfer files, you can right click on a file on your PC HDD and then select 'Send To' 'Infrared Recipient'. However, I did need to set up mRouter software that's supplied by Nokia.
I do like to use PC Suite for transferring image files and of course backing up the phone.
*edit* I did have to use the PC Suite for transferring all my contacts from my 7110 to the 7650. You need to make sure you install the Connectivity SDK so that you have Nokia Connection Manager installed.
S.
