Help!!! :(
8 replies · 1,777 views · Started 09 June 2004
This mornin i was messing around with ma fone and ma pc and i ended up formatting my mmc 128meg card on ma pc. Now it won't detect it!! I've tried formattin the card on ma fone and restarting the whole for to no avail.
Im on windows XP pro
On your PC use FORMAT with /FS:FAT /A:512 at the command prompt (see HELP FORMAT for more info). Let us know if it helped.
N/A wrote:On your PC use FORMAT with /FS:FAT /A:512 at the command prompt (see HELP FORMAT for more info). Let us know if it helped.
Please cud u tell me wat exactly to put in the command prompt (wen my mmc is detected its normally drive g)
Thx
Then, I'm afraid, you can only get a new/replacement MMC, because there seems to be something wrong with the one you have.
Boopop wrote:This mornin i was messing around with ma fone and ma pc and i ended up formatting my mmc 128meg card on ma pc. Now it won't detect it!! I've tried formattin the card on ma fone and restarting the whole for to no avail.
does that mean that you cannot format MMCs on windows or was this problem a one off?
You can format MMCs on Windows, but in this case the card seems to be bad/broken.
