phone calendar
9 replies · 2,559 views · Started 09 June 2004
i have a problem with the calendar on my phone. whenever i try to add a new entry into the calendar, it doesn't save into the calendar and neither does it save any of my settings on the calendar as well.
i have taken out the MMC and tried the calendar and works fine with no problems (exactly how u want it to). but as soon as i put the MMC back in, it doesnt save any settings, entries, etc...
this has led me to believe that theres something wrong with the MMC but dont know what it could be.
has anyone experienced this problem? anyone know of any fixes for this?
thanks,
DS.
heres a list of the application i have installed on my MMC:
Doom
RockitPinball
Retro Atari
Micro Pool
Planet Zero
Sky Force
Rally Pro
Overdrive
MIDP-Man (pac-man style game)
BLZ installer and SonicN
FeExplorer
could it be any of these thats affecting it?
Rally Pro is the known culprit that caused this problem (Calendar and To-do List). Another SW is Spycall....
Uninstall the SW and things should be backt to normal.
thanks Vamp, that worked a treat 😊 had to restart the phone and now i can use the calendar properly. cheers
Vamp wrote:Rally Pro is the known culprit that caused this problem (Calendar and To-do List). Another SW is Spycall....
ive already made another topic about this, rally pro erased all my calendar data, is there any way to take'em all back?
maybe this topic is batter than a new one.
thanks
p.
pusher wrote:ive already made another topic about this, rally pro erased all my calendar data, is there any way to take'em all back?
thanks
p.
Sorry... wats gone is gone... if u had backuped phone memory to MMC, you could restore from there.
i lost all my calendar entries as well but hopefully i should still have most of them backed up.
think i'll keep rally pro off my phone. do u know of any other software that causes similar problems like this?
DarkStarUK wrote:i lost all my calendar entries as well but hopefully i should still have most of them backed up.
Spycall....
