I've managed to snap one of the tabs off the keypad on my P800. Can anyone recommend anywhere I can buy another one please?
thanks
clum1
thanks
clum1
www.mobiltec24.de This shop sells all spare parts for both the P800 and P900. The P800 is 18 euro (if that is your currency...)
Delta737 wrote:www.mobiltec24.de This shop sells all spare parts for both the P800 and P900. The P800 is 18 euro (if that is your currency...)
Thanks for the info - unfortunately, I can only get the site in German and my knowledge of the lingo is non-existant. I'll try it later in case it's a temporary glitch.
clum1
www.mobilefun.co.uk do all the spares, and are fairly cheap as well. Ordered stuff from them a few times and service has always been good.
Well, the left frame IS actually english (unfortunately the rest of the site isn't) :s:
First click on Mobile Telephony --> Mobile Accessories --> SonyEricsson --> P800 --> Spare parts
It's on the second page. The text says (in short) "did you break your flip? install this new flip and you're ready to go
Cant start new thread, but does anyone know where I can get an external keyboard that links with my P 800 either thru bluetooth or IR? Especially something foldable and for travel like they have with PDA's?
[email][email protected][/email]
Don't know why you can't start a new thread, but anyway:
Here a BT solution (not yet available though):
http://www.thinkoutside.com/products/stowaway-bt.html
Here an IR solution (which is available):
http://www.p900er.com/product.asp?id=1260&model=p900
