Nokia 7650 firmware upgrade
2 replies · 3,508 views · Started 10 June 2004
hi there
I wondered if anyone had any information on how I could obtain a firmware upgrade for my Nokia 7650 - I had heard that an upgrade would allow me to use a Bluetooth headset and currently I can't. This is annoying!
My current firmware version is 3.16
Any information would be appreciated.
Cheers
Muffin
For a new firmware, find your nearest authorized Nokia service center.
But note that there are no firmware updates that will give you Bluetooth headset support for the 7650.
There are also Bluetooth headsets that plug into the standard headset connector (they have a Bluetooth module there, and then another in the earpiece part).
Hi! I'm planning to buy a memory card may i ask if 256MB MMC will work 3650 with a firmware of 3.13? I don't know if I'm going to buy a 128MB or the 256MB. Thanks a lot! Any help would be appreciated....
