How To Uninstall On A 6600
1 replies · 1,123 views · Started 10 June 2004
How do you uninstall a program from a Nokia 6600? I installed it with PC Suite and it doesn't work. Now I have the icon for the program but can't get rid of it. I tried to highlight the icon and click on "C" but it says "unable to delete".
Thanks.
You need to go into the application manager, hilight the program and press options then choose uninstall.
Hope that helps.
