Symbian Voice Disguise
5 replies · 2,518 views · Started 10 June 2004
hi is there any application that can change/disguise ur voice into male/female etc..... for Nokia 3650?? i looked almost everywhere but didn't find anything. i got a voice disguise device but it wasn't compatible with Nokia 3650... if any1 knows of any such software (symbian or java) plz let me know.
regards
leroy
Yeah, I�ve been looking for one too, I have an N-Gage but I haven�t even had the luck of finding one, working or not
What was the name of the one you tried? It may be compatible with other phones and others could use it
I'm not so much looking for a male--> female converter or vice versa but just one that will disguise my voice in some way
Wirelessly posted (Nokia N-Gage: NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)
*Raises an eyebrow*
What's with all you guys wanting to disguise your voice; what sorta trouble you guys chasing?
Tyrion wrote:Yeah, I�ve been looking for one too, I have an N-Gage but I haven�t even had the luck of finding one, working or not
on google just type mobile voice disguise/change & u'll get a list of sites which sell the device, it's a mobile handsfree kit with a tiny voice converter unit & u can switch b/w male & female voices, well i tried it again & this time it worked with my 3650, but there r some problems with it, such as voice quality isn't clear & b4 making live calls u have to record ur voice n test it 4 the desired output...also sometimes u'll have 2 plug & unplug it until the phone(3650) decides to work with it. well works like a charm once u get it working with ur phone. bt i'm still looking for the symbian or java application for the same....
I do agree cybacowboy, if u want to change your voice, then have a dog answer ur calls, :tongue: Joking aside, but it sure is cool if you can change your voice to like, dartvader or something 🙄 !!!
