hi all
After I bot this 7650, I've been absolutely fascinated... using MIDI files as ringtones. I love its natural and hifi-ish tunes...
okie.. can anyone share on the best sites for MIDI download, for best quality MIDI?
hi all
I think this shall help 😃
It's free ployring tones but everything else is part of registration .
Goto the midi u want right click save as
and TADA but u'll have to rename it ur self coz its saved as ploy and a number e.g PLOY 155 so you make sure to rename coz u'll just have a bunch of PLOYS on u desktop 😃 !!!
Peace out 8)
http://www.slacknews.com/index.php
Thats another very good one, that seem to have alot of midis that other sites dont have on it.
any midis with voice immitation like sound effects or someone speaking?
i have attached a nice one!
The mid file you posted is GOOD 8)
[quote="spy_2002"]any midis with voice immitation like sound effects or someone speaking?
i have attached a nice one![/quote]
you can also use .wav but to make it work you need to convert to:
bit rate: 176kbps
8 bit
stereo
format pcm
I tried other settings and it did not work.
after you send from the computer to the phone you need a program like seleq to copy paste to the ringtones directory (c drive where all the other .mid files are) and voila!!
[quote="spy_2002"]you can also use .wav but to make it work you need to convert to:
bit rate: 176kbps
8 bit
stereo
format pcm
after you send from the computer to the phone you need a program like seleq to copy paste to the ringtones directory (c drive where all the other .mid files are) and voila!![/quote]
I convert mine to 11000Hz 8 bit, Mono, pcm format and that works a treat for me. I use sound recorder that comes with window to convert it. I send by email to my phone. I don't need SeleQ to copy and paste. Just go to attachments, then save and it saves in your recorder, and show automaticaly in your ringtone list. 8)
bit rate: 176kbps
8 bit
stereo
format pcm
i think even mono sounds good because the phone only has a single speaker, it cut's down the half of the file
Nah man ya gotta go all the way
I use .wavfiles done in
Bitrate: 320kbps
32Bit dolby Digital 5.1 Sound
Sure it takes up the wholes phones memory for 5 seconds of audio but hey at least you can say if you ever attach 5.1 speaker setup to the phone it will work fine 😊
Just joking ya'll 😊
hi, btw what software do you all use to convert the bitrate and stereo to mon on your pc ??
bit rate: 176kbps
8 bit
stereo
format pcm
Hmm, I did download a lot of wavs, I didnt convert them to anything and I didnt copy and paste them, only send them per IR to the 7650 and save them and they all work properly and are automatically found as ringtones ...
[quote="ericssan"]
okie.. can anyone share on the best sites for MIDI download, for best quality MIDI?[/quote]
When I search a midi I dont go to one of the midi sites (there are a lot of good ones) but enter "title midi" at google.com and did find everything that way ... 😊
