Smartmovie converter help
1 replies · 3,011 views · Started 11 June 2004
hi, umm...when i start to convert a movie with smart converter, at different points in the conversion i get
Machine: 'DANIEL', OS ver: 5.1 (build 2600)
Memory: 255 MB (used 77%)
Date: 11-6-2004 21:16
Address: 1b:00eb7a88, Exception code: c0000005 (ACCESS_VIOLATION)
Registers:
eax = 049a0220, ebx = 000000a8, ecx = 04747a60, edx = 000000a8
esi = 00001540, edi = 0435fc00, ebp = 00000000, esp = 0435f4f0
Execution path:
Module: xvid_dshow.ax
DllMain, offset 0x69b8
could anyone help with this?
dv8r wrote:hi, umm...when i start to convert a movie with smart converter, at different points in the conversion i get
Registers:
Execution path:
Looks like you have a problem with your Xvid codec. Uninstall it and download the lastest one, that should solve your problem.
If it doesn't try a different converter or a different version of smart converter.
