Now that I'm starting to get to grips with Theme Studio, I was wondering if it's possible edit/use elements (icons, etc.) from other people's created themes.
Do you need the original .tpf file, or can you rename a .sis file and import it to Theme Studio?
This is probably another one of those murky areas, so to clarify, I will just say that I would only be interested in using free themes for such a purpose.
Editing existing themes
Check out the attached PDF file, it may be of use to you mate.
I wrote this myself and it worked out ok, quite a few people have used it and seem to be able to follow it nicely.
See what you think.
Ian
coolice wrote:Hi,Check out the attached PDF file, it may be of use to you mate.
See what you think.
Ian
:icon14: WHOA!!! Cheers Ian :icon14:
(That's a beer I owe you!)
Sandinista wrote::icon14: WHOA!!! Cheers Ian :icon14:
Hey Mate,
Your welcome. Only just spotted the compliment, thanks.
Ian
