Trying to improve 😉
Sphere 2
:icon14: I prefer it to the other sphere theme :icon14:
Love the idle and background!
I'm not so sure that the calendar image works, but that is just my opinion. 😊
Is it just the screenshot, or have you managed to vary the text colouration across the navi pane?
:? If so, how? :?
Most of the ones I make would benefit from setting a different colour for the antenna and battery icons.
Thanks Sandinista for your comments,
The picture for the calendar is not very good, looks better installed on the phone. But you're right, it's perhaps a bit too confusing. For the icons, as usual, already installed ones should have to be selected :redface:
