It would be nice if under contacts there was a tick box for 'supports MMS/color screen'.
Useful for when MMS'ing' images.
I do something similar with contacts by adding a 'Detail' called Network so I can keep track of what Network they are on. When you mentioned can probably be done in the same way.
thats ound slikea good idea
but wouldnt you have to check their profile EVERY time you go to send them something
or does it come up with the ph, mob, email settings like whever else you select them? you know what I mean?
A screenshot would be great too, I really like the sound of this setup.
If it was a built in option (which it isnt(, then the phone would only show MMS users when selected...
why not just use default for this..
set the phone number as MMS default.. kinda gives you what you want.
[quote="crabman"]why not just use default for this..
set the phone number as MMS default.. kinda gives you what you want.[/quote]
I havent done enough exploring, but you may be right 😉
i hav some problem with contact that seems annoy me a lil bit
for example when on standby screen i press the joystick to enter the contacts and then i find the person that i want to call. After that i select the option call, then after i ended the call the contacts still running in the background. I think after i select call the contact should close.
is it just me ????
On the subject of Contacts, does anyone know if it's possible to have the order of names swapped round, so the person's first name is displayed before the surname?
I came across a program that claimed to do this, but it simply swapped the fields, so that the person's surname was placed in the "First Name" field; which really isn't ideal.
The 9210 can do this, why can't we? :-?
