I need urgently help on Nokia 9210
1 replies · 1,903 views · Started 12 June 2004
I format my Nokia 9210 and after the formating it doest not connect to my computer again and I want to load new software into it. I have try to connect my Nokia 9210 to two different computer but it doest not conneted. I even try another Nokia 9210 into the two computer and it connect, but my own does not connected. Please friend what can I do?
[email protected] wrote:I format my Nokia 9210 and after the formating it doest not connect to my computer again and I want to load new software into it. I have try to connect my Nokia 9210 to two different computer but it doest not conneted. I even try another Nokia 9210 into the two computer and it connect, but my own does not connected. Please friend what can I do?
Friend what do you mean not connected(is it "via infrared device" or for "software cables"😉
If via infrared device make sure that your communicator system is active to this kind of connection,Try to check your infrared.
If via device cable a lot of times the lower portion of 9210 losses the contact on the buttom part via connector socket of the board if you can tighten the screws below or adust the contact inside the connector lm sure you can connect your phone to your software.Just be specific to your problem for others to understand the thread.Good Luck!!!
