Theme Editor and Photoshop CS
3 replies · 1,945 views · Started 12 June 2004
Hey all you theme writers out there. I wanted to try my hand at a theme or three, but I am having issues. I was able to get the theme editor install on my XP box, but I keep getting error messages from Photoshop that it's the wrong kind of file. Has anyone seen this?
Hmmm... I don't use Photoshop, but I suspect you may be using software incorrectly.
When you're tailoring images in Photoshop (cropping etc.) save any that you want to use in the theme as a .bmp file (you might want to create a new folder for this 😊 ). Now if you enter Theme Studio you can retrieve it by using the browser in the top right-hand corner of the window and incorporate it in your theme.
Don't know if this is the answer to your problem. If not, can you be a bit more specific about what you are doing when the error message occurs?
Sandinista wrote:Hmmm... I don't use Photoshop, but I suspect you may be using software incorrectly.
What do you use instead of Photoshop?
'Photo Impressions' (it came with the webcam). Same sort of thing, a little less sophisticated, but a whole lot cheaper 😃
