Some voice commands don't seem to work
3 replies · 2,756 views · Started 13 June 2004
Hi all,
Just purchased a 6600 here in Australia. Pretty happy with the phone so far. One problem I'm having involves voice commands opening apps.
Most commands seem to work ok (eg. dialing numbers, bluetooth, camera, clock, converter, and setting). Some, such as 'app. manager', 'new message', and 'notes', don't seem to work at all. Nothing happens - the phone asks for voice input, it recognises the command ok, but nothing happens.
Can someone verify whether these commands work.
Mick
V 3.42.1
16-10-03
mikeyjames wrote:Hi all,
Mick
V 3.42.1
16-10-03
I'm not sure, I get voice recorder to start w/ my headset so it seems like those would work as well. You may be able to add them again or something. Unless I'm wrong you have really old firmware so that might be a problem.
JasonT wrote:I'm not sure, I get voice recorder to start w/ my headset so it seems like those would work as well. You may be able to add them again or something. Unless I'm wrong you have really old firmware so that might be a problem.
I've tried deleting and adding again, but for the apps I've mentioned nothing seems to work. BTW I just tried voice recorder and it works fine for me too from a voice command.
Can you get 'app. manager', 'new message', or 'notes' to work from a voice command?
thanks
Mick
lucky for all of you,at least it worked for some task.in my 6600,voice commands doesn't work,i say the command exactly as i recorded it but no response from the phone.
